Welcome to the Sales and Wants Section.
It would be greatly appreciated if advertisers would remove their adverts once they have been fulfilled. This will help prevent further enquiries.
This is easily done by opening the thread and deleting your original post.
It is quite understandable that this step may be forgotten, and to help keep adverts relevant, the section is now set to hide adverts after 20 days of inactivity. If you want to keep your advert, simply add a reply, and this will reset the 20 days.
If your advert has disappeared and you want it back, this is easy to achieve, as outlined below.
Having selected the 'Sales' or 'Wants' section you should have a similar view to that shown below. To show older adverts use the drop down box circled and select the period you wish to view, then hit the 'Go' button to the right. This should reveal more adverts, and to return your thread to the top and restart the 20 days, simply post a reply. Don't worry, the next time you select the same forum it will return to the default 20 day view.
