Warning [2] Undefined variable $search_thread - Line: 60 - File: showthread.php(1617) : eval()'d code PHP 8.1.33 (Linux)
Starting Dog
Can anyone please advise if I can use a coil engine starting dog on a mag engine? I have a crank which suits only a coil starting dog, and since I don't have a lathe to hand, it would be simpler to substitute the later dog, than modify the magneto engine dog that I have.
Thanks!
Not easily, if you wish to use the starting handle or stop oil flying out the front.
I can modify the mag stater dog to suit the crank you have and return it to you the same day - if that helps.
Message me for details.
Thanks so much. Will do.
John
