Warning [2] Undefined variable $search_thread - Line: 60 - File: showthread.php(1617) : eval()'d code PHP 8.5.8 (Linux)
Van Print
I picked this up a few weeks ago at a local transport show. Correct me if im wrong but i can only presume that if you wanted your van sign written then you pencilled in your design to give to the sign writer. It is printed in 1/16 scale and judging by the age of the paper appears to be original and not a re print. Im thinking of framing it to put in the man cave  Smile
Yes, these prints were issued for personal signwriting.
Mike, did the factory ever produce similar prints for the AD bodied Vans?
Thanks,
Stephen
I don't think so, because they were not built at Longbridge - they were sold through the Austin dealerships, but were bodied by Startin. I've seen a similar print for the AVJ van, and there may well have been similar ones for the high-roofed version.
Yes, Sheddweller, what you have is an original. I have a similar one but ( sorry ) mine's in mint condition with no creases. They are rarely found.
Yes it is a shame about the crease in it but i didnt think it was bad for a fiver
Creases? No problem....
Do you have four copies or an itchy trigger finger  Huh
Seeing that image reminded me of this.
.jpg   2 Trotters_Independent_Traders_-_Reliant_Regal_rear.jpg (Size: 80.37 KB / Downloads: 284)
Just the one copy , was trying to get to grips with attaching image and posted the thread before checking it  Confused
