Warning [2] Undefined variable $search_thread - Line: 60 - File: showthread.php(1617) : eval()'d code PHP 8.5.6 (Linux)
Side water manifold studs
What is the thread tapped into the block for the studs that hold the side water manifold?
BSF or Whit?
Thanks
I think from memory it’s BSF.
NEXT TIME IN THE GARAGE I WILL CONFIRM
Yes I can confirm it’s 5/16” BSF
NOT sure if all engines the same.
That’s a 3 bearing Ruby
(17-12-2021, 01:06 PM)Tiger Wrote: I think from memory it’s BSF.
+1
I’ve just installed a side branch on a 1930 engine.
Thanks
