Car type: 1928 Austin Seven (56S Box Type)
Hi Hugh,
As long as I know, Chummies up to 1929 had a Speedo bezel with four nuts and a 90º drive outlet. Speedo model PA.
The one shown is a PN and may be have a 45º drive outlet.
Cordially,
Bert
24-02-2021, 09:50 PM
(This post was last modified: 24-02-2021, 09:51 PM by Parazine.)
Later (November '27 on) Chummies and saloons also use a PA.
I think the photo shows an early Austin 10 speedometer.
If I remember correctly, my 1934 Austin 10 was fitted with a PN speedo.
Ah, so not 7 then...
Thanks all...
Car type: 1932 RN saloon
Would the boat tail 2 seater tourer of 29/30 have that speedo, considering that there was an arc shaped cutout in the dashboard to clear the gearlever/ handbrake? So rather than the cable coming down vertically to the speedo take off on the gearbox, the cable was offset. I may be entirely wrong!
Hi
If you are thinking of using it in a Seven the gearing may be wrong. They are not easy to recalibrate unless you use a gearbox on the drive cable.
