Lower Chummy windscreen rubber channel. - Printable Version
+--- Thread: Lower Chummy windscreen rubber channel. (/showthread.php?tid=9956)
Lower Chummy windscreen rubber channel. - Ruairidh Dunford - 19-04-2025
Does anyone currently sell the rubber channel that goes between the top of the scuttle and the curved bottom of Chummy windscreens?
RE: Lower Chummy windscreen rubber channel. - Robert Leigh - 19-04-2025
I have not seen this from any of the usual suppliers. My car has an original rather manky looking perished strip with bits of paint from its early days. I wonder whether a split rubber tube from Woolies might do the job. I use split heater hose around the cockpit sides on my Ulsteroid.
RE: Lower Chummy windscreen rubber channel. - David Cochrane - 19-04-2025
Not that I know of Sad  I haven't been able to get any for several years.
RE: Lower Chummy windscreen rubber channel. - Tony Griffiths - 20-04-2025
My chummy windscreen frame appears to be 13 to14 mm thick, and this, I'm sure, is the strip that I used: https://www.woolies-trim.co.uk/p-1787-rubber-extrusion
RE: Lower Chummy windscreen rubber channel. - Bryan - 21-04-2025
Tony had some on eBay last week.
