Mileometer (Odometer) mystery - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Mileometer (Odometer) mystery (/showthread.php?tid=9937) |
Mileometer (Odometer) mystery - davidfmarks - 06-04-2025 I have recently become the owner of a 1934 APD on whivh the odometer is not working (speedo seems OK). I have studied the excellent article on th Brristol clubs web site and have run into trouble ! I have removed the instrument fronm the dashboard, removed the two screws at the rear and removed the glass and the front panel. I cannot however get the guts of the thing out of the case. I almost comes out (see photo1) but appears to be prevented by a circular projection with the slot carring the pawl which should operate the ratchet. This pawl is stuck fast clear of the ratchet (clearly why the mileometer is not working !). To add to the mystery a small special washer (see photo) was loose in the bottom of the casing and a thin metal ribbon was seen protruding from under the right hand number wheel (see another photo !)l. I am reluctant to use my usual solution (violence !) as I dont want to wreck the speedo. Any advice would be most welcome. I am new to this game and not being accompanied by granchildren am hoping that I have added the photos OK without breaking any rules RE: Mileometer (Odometer) mystery - bob46320 - 07-04-2025 Isn’t the washer meant to stop the speedo cable from shrinking back into the sleeve? RE: Mileometer (Odometer) mystery - David Stepney - 07-04-2025 Yours is a Magmo speedo. There is quite a useful article about these on the Bristol Austin 7 club site www.ba7c. |
