Zenith 26VA carburetor minor differences - Printable Version
+--- Thread: Zenith 26VA carburetor minor differences (/showthread.php?tid=9934)
Zenith 26VA carburetor minor differences - GM6VXB - 05-04-2025
Doing a complete re-build on a spare 26VA carburetor. It is marked '7' on the flange so know it
is the correct one for the car.
The difference I notice is the mounting screws for the emulsion block.
The diagram/ service bulletin I have shows four screws to fix it to the carburetor bowl, the one
I am re-furbishing only has three !, two toward the top and one toward the bottom.
Also the emulsion block has 'MK2' stamped into it.
Checks with a new gasket show all the holes line up with only (possibly) a
smaller gap where the bottom screw goes through one of the fuel passageways.
I do not think this will cause a problem though as it would have always been this way.
So it looks like there maybe a MK1 and MK2 version of the Zenith 26VA, so more for interest
wondering when the crossover from MK1 to 2 was as the carburetor should be
from circa 1933-34 and the bulletin gives dates from 33 to 39.
Also found what appears to be a flame trap in the manifold which appears to
be original. Never seen one before so removed it. Do like flames out the carb when
it backfires !.
Martin, GM6VXB
RE: Zenith 26VA carburetor minor differences - John Mason - 05-04-2025
I can only say that my Mk1 Ruby has four screws holding the beak to the bowl, I can tell you there are two types of Zeneth carb both work well provided both halves of the carb are from the same design.
John Masonry
RE: Zenith 26VA carburetor minor differences - Robert Leigh - 05-04-2025
I suspect that your 'flame trap' is an economy device which supposedly gave better fuel atomisation. I have no knowledge of whether such things worked, having no personal experience.
RE: Zenith 26VA carburetor minor differences - John Cornforth - 05-04-2025
I agree about the economy device. Apart from restricting airflow I doubt if it did very much. The Zenith does a pretty good job of atomisation, especially with modern fuel having fewer "heavy" fractions.
RE: Zenith 26VA carburetor minor differences - Mike Costigan - 05-04-2025
Robert and John are correct, it was a period accessory, I forget the manufacturer; I had one and tried it on my 1937 van - it didn't appear to make any difference (either way).
RE: Zenith 26VA carburetor minor differences - GM6VXB - 05-04-2025
Thanks for putting me right about the flame trap. As an economiser it might work, but as
suggested probably no noticable difference.
I have removed it from the spare manifold anyway and waiting for a slightly warmer day
before I coat the manifold with some VHT paint.
Still working on the carburetor and waiting for parts for the final re-build.
Choke assembly was virtually siezed. Cleaned up and with a modified return spring it
now works correctly.
Throttle spindle was very badly worn, being replaced.
An hour in the sonic cleaner has got the body cleaner.
Even managed a drive (20 miles) in the Tourer this afternoon when the sun came out.
Still cold so coat and gloves needed.
Martin.
John Masonry
If your work on the carburettor does not improve things it could be worth sending it to Steve Hodgson. He has done a lot of good work on vintage and later Zenith carburettors, fitting new spindles and bushing the body if necessary, apart from really thorough cleaning.
RE: Zenith 26VA carburetor minor differences - GM6VXB - 06-04-2025
Robert,
Work on the carb is pretty straightforward, easier than Weber 40DCOE's were !.
Fortunately the hole for the throttle spindle 'should' be close enough to tolerance, but
will check it carefully when the new spindle arrives. Got a fairly good pilar drill and lathe
here so if it does need boring and bushing then happy to do this myself.
Hopefully a few pics attached of the (still dirty) carburetor. Will be going into the
ultrasonic cleaner again with a slightly stronger cleaning solution.
Note the picture of the emulsion block.
Only three attaching screws, and showing 'MK2' if you can zoom in.
I know from searching there is a type one and type two carburetor, but non of the
pictures I have found show the screws on the emulsion block, so maybe this could be
a type three carburetor ?.
Martin.
RE: Zenith 26VA carburetor minor differences - andrew34ruby - 06-04-2025
The 'flame trap' in the manifold looks like a Mangoletsi manifold modifier. These were advertised in the motoring magazines of the 1960s as an economy device. The idea was that any drops of petrol would be caught by the mesh and would be broken up into a fine mist, thus being burnt rather than just going into the exhaust as drops of petrol.
