Rear axle inner lip seal - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Rear axle inner lip seal (/showthread.php?tid=9933) |
Rear axle inner lip seal - David Aylmore - 04-04-2025 I am rebuilding a D type rear axle and have bought modern lip seals for the inner end of the half shafts. They are a very loose fit in the axle case but won't fit in the cups which held the original felt seals. Can someone please advise on how the modern seals should be fitted? Also, does the surface of the half shafts have to be smoothed where the seals fit? Many thanks in advance. RE: Rear axle inner lip seal - Denis Sweeney - 04-04-2025 David, it is some time since I rebuilt my rear axle on my ARQ Ruby (D Type) in which I used modern lip seals, I cannot recall the seals being loose on the axle but they were a tight fit into the original housing which the original felt seals were located. I checked with the supplier and was advised the seals sometimes need to be lightly dressed on the outside to enable them to sit in the housings. The light dressing was carried out using a very very fine flat file and regularly checking the fit. I do remember that the felt seal plate still has to be used with the modern lip seal. And a light oil film should be used on the seal when fitting up. There is a great paper which I followed to complete the stripping and rebuild of the D type axle by Fred Gauci, from my point of view it was a great help. Cheers RE: Rear axle inner lip seal - Dave Mann - 04-04-2025 I think the tolerance on the seal housing bore is very wide, I've just done a D type axle one seal was an easy fit and was fitted with Loctite retaining compound the other was a tight fit. I seem to remember I had your problem some years ago and I machined a pair of sleeves to take up the gap. RE: Rear axle inner lip seal - Terrytuned - 05-04-2025
Axle Shaft oil seals update.docx (Size: 2.58 MB / Downloads: 57)
Axle shaft oil seals update. Terry.
RE: Rear axle inner lip seal - Ruairidh Dunford - 06-04-2025 I also find the lip seals a tight fit in the cup and often find myself reducing the outside diameter with a bench mounted wire wheel. Like Terry, I have found o-rings very useful for fitment and sealing. RE: Rear axle inner lip seal - Stephen Barker - 06-04-2025 The article about Fred Gauci rebuilding a rear axle is in the Essex Austin Seven website. www.ea7c.org. Stephen |
