Linear vacuum wiper motor - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Linear vacuum wiper motor (/showthread.php?tid=9910) |
Linear vacuum wiper motor - Dave Mann - 22-03-2025 Has anybody come across one of these? Google hasn't, it is fitted to a 12/4 London taxi belonging to a friend. RE: Linear vacuum wiper motor - Robert Leigh - 22-03-2025 It would help if you gave an idea of what it looks like. RE: Linear vacuum wiper motor - Dave Mann - 22-03-2025 It's an 1.5" diameter mounted front of the windscreen peak for the full width of the car with two wiper arms hanging down. RE: Linear vacuum wiper motor - Robert Leigh - 22-03-2025 Do you mean it is as long as the windscreen is wide? RE: Linear vacuum wiper motor - Tony Griffiths - 23-03-2025 Vintage Austin Taxi wiper motor. It certainly is a most remarkable thing - a vacuum tube fitted at the top of the windscreen that stretches across its entire width. The picture shows the assembly held on brackets at each end - and the vacuum pipe running down the edge of the windscreen. RE: Linear vacuum wiper motor - David Stepney - 23-03-2025 How interesting! It looks as if it wipes linearly as well. RE: Linear vacuum wiper motor - bystander - 23-03-2025 See also a 2018 post on an Autoshite thread by Soap Distant (unfortunately no picture): https://autoshite.com/topic/31307-possibly-the-weirdest-wiper-design-ever/ RE: Linear vacuum wiper motor - Dave Mann - 23-03-2025 Thanks Tony, the one I saw on Friday when I returned the dynamo was in a somewhat dark garage and was missing the drivers wiper arm. The question is whose make is it? |
