Clear out parts from AD to AG's - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Sales (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Clear out parts from AD to AG's (/showthread.php?tid=7483) |
Clear out parts from AD to AG's - David.H - 08-05-2022 All parts are usable, used spares unless specified. Postage & packing at cost (up to 2kg £3.00) "Every thing must go!" Fan pulley eccentric shaft for coil engine complete with original square nickel(?) grease nipple £5.00 BA 239 original Bottom pulley. taper a bit scruffy £2.50. Ditto REPRO (no casting number mark) NEW £17.50 Planet wheel for 1/2" "D" shaped shaft with bush fitted appears new? 1.5/8" max o/d 1.1/8" smaller dia. £4.00 Matched pair timing gears (well - tied together with VERY old string!-) 30 tooth 1A486 (0 2) & 15 tooth (0 1) Very small chip out of one tooth on large gear. £15.00 Chummy side screen socket bracket and pair of hood frame hinge supports (no idea how these got left over...! Can email photos £6.00 lot Used but sound pair of 3.5" kingpins (diameters 0494-.497 & .204/.508) £6.00 TRE Ball pin (new) plus spring with cup & solid cup. £5.00 3x spark plugs (NAPA 581) & 2x Champion K17 £5.00 lot Pair if bob weights with pins (brass) and 2.0 needle valve assembly for Zenith bronze 22FZ Carb £4.00 Very early Lucas Distributor cap Marked "LUCAS Type DJ 4" and the outlets helpfully numbered 1,3.4.2 (and notched by stupid previous owner who could not read!) complete with 5 acorns, no centre carbon brush/spring. Probably a curiosity with the embossed markings rather than one to use...but it MIGHT work! £7.50 (worth it for the acorns!) Any questions please ask. Not easily offended by offers on bulk deals! David RE: Clear out parts from AD to AG's - Vancevr - 10-05-2022 Do you have a wheel rim for a 1929 tourer and front side screens? RE: Clear out parts from AD to AG's - GCD - 11-05-2022 David Will have the Dist. body off you, if I may, for the £20.00 + P&P Will try and PM you, but not done this before, so it may all go pear shaped GCD RE: Clear out parts from AD to AG's - David.H - 16-05-2022 sorry none of those D |
