various bits - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Sales (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: various bits (/showthread.php?tid=7370) |
various bits - JonE - 06-04-2022 pair of 4.00 x 19 tyres good tread but old £15 Austin stamped early hub centre screw cap/cover £15 heavy Steel screw on cover; seems same thread as the dust caps and longer in body £8 1 1/2" spring pipe bender 2 feet long £20 33 no. countersunk crosshead type machine screw 1/4 BSF 1/2" (0.71 inch full length) £5 big spring for door glass mechanism £6 Torque tube mount screw top (base) £7 late starter dog £8 chummy updraft manifold £13 presentable pressed steel brake drum £13 Speedex nut remanufacture £9 each or hefty discount for the last set of 12. goodish 22FZB casting £25 good original bonnet catches pair, down to the knuckle part. £ GONE new old stock flexi joint £10 Syn gearbox 4 speed top casting £10 screw brake adjusters £ GONE oil pump complete with innards, drive, both bolts £GONE box inner handles - not original £ GONE cut down tappet guides set £ GONE SU GX needle £5 new Austin patent plate repro £GONE Herbert Austin book by Roy Church £14 now 12 reamer Dormer taper pin 1/4 inch new boxed £ GONE T handle stainless steel with c.8mm reamer £6 special pedal brake and (welded) original pad - shortened under pad by 2" £ GONE special pedal throttle with stop for hand throttle, but very altered £10 Ruby manifold £ GONE Brooklands screen brackets and securing bolts £ GONE pair rubbolite rear lights dual pole with side illumination panel, round lens of porkpie area.. new old stock £55 now 45 (note these are not Divers helmet type) pm an email address for photos |
