cylinder head with reversible water outlet - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: cylinder head with reversible water outlet (/showthread.php?tid=5920) |
cylinder head with reversible water outlet - JonE - 06-04-2021 anything out there sitting on a shelf, useable and with a still-reasonable compression ratio? Running fine with '37 head but water is presently going round the houses to get to scuttle header tank. An alternative would be a home-converted HC outlet to go toward bulkhead if anyone has mucked around with same issue in past. |
