FOR SALE 1931 RN (need space) - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Sales (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: FOR SALE 1931 RN (need space) (/showthread.php?tid=4995) |
FOR SALE 1931 RN (need space) - DazeOff - 25-09-2020 FOR SALE 1931 RN - Untouched for many years, saved from oblivian and quite original. 2 bearing engine (number tallies with year), updraft carb' 3 speed box, clutch vicious but OK, NEW prop' flexible coupling, electric start - motor INSIDE cab (as with year) manual advance/retard. New battery (with isolator) New front spring, new bushes, Bowdenax front brakes, all shoes OK, gravity feed tank on scuttle, new safer petrol switch, water filter, new brake light circuit, rewired pear shaped control, bodywork & paint excellent, no leaks, radiator OK, 6volt dynamo pumps out 20 amp, Pork Pie rear lamps rewired to LED, LED projector beam headlights in original body (with running halo, yellow halo turn flashers) Removanle Magnetic rear secondary rear lights, hazard warning, chasing amber turn signal). NOW lorries can SEE the car safely. All can be returned to original. Freed sun roof and cleared drains. Tyres LOOK brilliant but probably stored under-inflated. Interior headlining original, all leather excellent. Used daily and under cover BUT I NEED THE SPACE as I have 2 others. £6250 o.v.n.o. Stockport : 07712887993 : beeaware@icloud.com for photo's. This car is also 'For sale' on other sites. |
