XL1195 Camshaft - Printable Version
+--- Thread: XL1195 Camshaft (/showthread.php?tid=4462)
XL1195 Camshaft - Simon Anderson - 03-06-2020
Hello All,
I am in the process of freshening up my maggy motor and i have come across a cam in my bits and pieces. It has the markings of XL1195, my other two have no markings on the.  the profile is a little taller. is there any info on cams?
RE: XL1195 Camshaft - Archivist - 03-06-2020
Hello Simon..
You could start your research here, perhaps...
http://archive.a7ca.org/wp-content/uploads/IC_A7_BB.pdf
hth....
RE: XL1195 Camshaft - Simon Anderson - 05-06-2020
Thank you
RE: XL1195 Camshaft - David Stepney - 05-06-2020
Have a look at Tony Betts' thread 'Unusual mag Engine Camshaft'. He appears to have a similar problem.
