Rear light glasses - clear version available? - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Rear light glasses - clear version available? (/showthread.php?tid=3385) Pages:
1
2
RE: Rear light glasses - clear version available? - Tony Griffiths - 06-10-2019 (06-10-2019, 05:51 PM)Austin Carr Wrote: Ruairidh, if you can't find a clear lens, is 3D printing an option? In my (very limited) experience it's possible to 3D print coarse threads with a home-type priinter, but not in this case with its large diameter, thin wall and fine pitch. Still, might be worth a try if one has a few hours to spare... RE: Rear light glasses - clear version available? - Hedd_Jones - 06-10-2019 be easy enough to cast a silicone mould from an exisiting lense. Then liberate the bronze thready bit and cast a clear one in resin. Might be easier to turn one on a lathe from a lump of clear resin however. Then glue in the thread. RE: Rear light glasses - clear version available? - Tony Press - 06-10-2019 (06-10-2019, 04:34 PM)Ruairidh Dunford Wrote: Thanks you for taking the time to do that Austin - those are not quite right unfortunately. Only ever seen the orange lensed indicator version without the side window as an alternative but seeing the other variants with a plain lens it might be available. Ask the Complete Automobilist or Paul Beck. https://www.vintagecarparts.co.uk/ RE: Rear light glasses - clear version available? - Dave Mann - 07-10-2019 I bought some original style glass lenses from John Barlow, these fit inside the brass threaded section which I carefully removed from inside the plastic lens. So I suggest that you extract the threaded ring and take it to a glass merchant and ask for a 3mm glass disc to fit it. My camera doesn't like being dropped from a great height onto a concrete floor. RE: Rear light glasses - clear version available? - AllAlloyCup - 07-10-2019 Hi Ruairidh These lenses have a threaded brass insert. I reckon you could make rubber mould of the red lens , cast it in liquid acrylic, then Machine the casting and insert the brass part. Tom used to cast the GE front lamp lenses this way I think. Regards Bill G RE: Rear light glasses - clear version available? - bob46320 - 07-10-2019 You would need a threaded brass insert, but are these any good ? https://www.autoelectricsupplies.co.uk/product/777/category/70 RE: Rear light glasses - clear version available? - Ruairidh Dunford - 07-10-2019 Thank you for all your suggestions everyone - very helpful. RE: Rear light glasses - clear version available? - Tony Press - 07-10-2019 All the suppliers appear to have stopped stocking the reproduction Lucas AT 201L tail lamp ! This was a copy of the original style with a black screw on cap. I bought one- removed the ribbed plastic insert and fitted a clear piece of plastic from some packaging as the side lens plus an original red glass lens and it is almost indistinguishable from the original . It appears as though to do this now you have to somehow take off the red or orange plastic lens from the brass insert |
