All Alloy Cup progress - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: All Alloy Cup progress (/showthread.php?tid=1822) |
RE: All Alloy Cup progress - AllAlloyCup - 16-06-2019 Why not have a motorcade to Coldingham? Tea and coffee awaits! Regards Bill ag RE: All Alloy Cup progress - Ruairidh Dunford - 16-06-2019 That would have been nice Bill - thank you - I hope that you will be able to join us next year in your own Seven. RE: All Alloy Cup progress - AllAlloyCup - 17-06-2019 JiThe big day for the All Alloy Cup! Spent an hour filling the radiator, gearbox and engine fluids. First problem of the day , had to remove The number plate as I had forgotten to close the Drain tap! And access wasn’t otherwise easy! Secondly had to tighten up most hose clips But then water started running out the two studs holding the side water manifold. Drained out the remaining water And refitted the stainless studs with red fibre washers coated in WellSeal and with Loctite thread lockn’seal on the threads Adding the oil and petrol was a deal simpler! After lunch Neil came and we checked that we had a spark, But decided the petrol supply wasn’t working. Discovered that the float control lever needed more bending Easily done! Pressed the starter for the first time and it fired up without Any adjustment to the carb or the distributor!!! A small adjustment to the throttle control lever linkage And it ticked over about 500 revs! Slow and steady! 4lbs sq inch on the oil gauge so all is well there too. Neil joined me in cockpit, a tight fit you could say! And we set up up our unmade lane Past the School on to the main road, down the hill through the village and back up our road from the bottom. Used all the gears! One of the rear backplates was catching the root of some spokes But a mole wrench soon sorted that out. Basically we were extremely happy that the coil engine build and initial tuning set up was so smooth running. Currently it’s on an old DK4 distributor but may also try the Accuspark I bought Earlier. We then fitted the bonnet, but a modest amount of adjustment will be needed here, plus the radiator will need to come off again as the indicator lamps are fouling the lower bonnet sides plus I need to get in to tighten a couple of bolts that were not full locked up. Otherwise a great result and am very , very grateful to Neil for all his patience and engineering expertise in helping me get to this stage. I have a short video but don’t know how to post these to the Forum. Uploading to YouTube? Lots of adjustments needed now especially brakes , rattily gearstick etc All pretty down hill now ? I hope!!! Kind regards Bill G Ps now need to get it off SORN and insured Ops forgot to mention Dynamo not outputting and the cutout Doesn’t seem to be working will need to check the wiring....... RE: All Alloy Cup progress - Peter Naulls - 17-06-2019 Great news Bill, it's a good feeling isn't it! Peter. RE: All Alloy Cup progress - David Stepney - 17-06-2019 Excellent news! Well done! RE: All Alloy Cup progress - Ruairidh Dunford - 17-06-2019 Well done Bill! Was the 4lbs from cold? RE: All Alloy Cup progress - Howard Wright - 17-06-2019 Cheers Howard RE: All Alloy Cup progress - AllAlloyCup - 17-06-2019 Hi Ruairidh I think it started about 4lbs but came down only slightly After running for about 20 minutes . The gauge is a bit sticky and needs a little tic. Regards Bill G RE: All Alloy Cup progress - "Slack Alice" Simon - 17-06-2019 So pleased for you. Its a great feeling, that first drive. RE: All Alloy Cup progress - Ruairidh Dunford - 17-06-2019 The oil pressure should go off the gauge when cold Bill - it will come down to around 3lbs or so after being warmed up fully. You may have a faulty gauge or you may have fitted the oil pump vanes upside down - the chamfered ends go to the top of the engine. Try another gauge if you can, initially. I can send you one that I know works, if that helps. |
