Nippy lighting set 1936 - on - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Sales (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=10) +--- Thread: Nippy lighting set 1936 - on (/showthread.php?tid=11084) |
Nippy lighting set 1936 - on - Stuart Joseph - 11-10-2026 I have available a lighting set for a Nippy 1936 on. It comprises a pair of L131/133 refurbished headlamps replated with dipping projector bulbs. A pair of nos Lucas LD109 sidelights and a nos ST38 pork pie lamp. Cost is £550 to include p+p to UK. RE: Nippy lighting set 1936 - on - sjnh10014 - 30-10-2026 This looks interesting. My car is 1934 but the headlights are not correct so this may be a step in the right direction. Do you have pictures you can send? Thanks Steven RE: Nippy lighting set 1936 - on - Stuart Joseph - 31-10-2026 Thanks for the reply. Could you send me an email to stuart.joseph@btinternet.com as I have problems downloading photos to this site. Your 1934 lamps should be Lucas LB130’s which are identical in function to my later lamps (same glasses etc) the bowls/shells are a little different. The sidelights are identical as is the ST38 ‘pork pie’ rear lamp. |
