Electronic ignition - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Electronic ignition (/showthread.php?tid=10558) |
Electronic ignition - timbigden@icloud.com - 11-01-2026 Any views on the DK4A distributors with Accuspark electronic ignition from eBay? My car has had the original manual advance dizzy replaced with an Autoadvance DK4 and timing seems very inconsistent. RE: Electronic ignition - Tony Griffiths - 11-01-2026 This earlier post might help you to decide: https://www.austinsevenfriends.co.uk/forum/showthread.php?tid=9651&pid=104782&highlight=electronic+ignition#pid104782 RE: Electronic ignition - AustinWood - 11-01-2026 We fitted an Accuspark which worked well but the electronic unit failed very quickly and was replaced. That was fine for a long time but started to become unreliable. It would fail and then recover after a rest. We have modern HT leads but the original coil and I think Accuspark prefer a high impedance coil - a 12V unit works. However I bought a powerspark electronic module while requires modern leads but is OK with a 6V coil and have had no further trouble. The Accuspark distributer itself works well. The car runs more smoothly, probably because there is less timing scatter. RE: Electronic ignition - David Stepney - 11-01-2026 Being the Luddite that I am, I much prefer the original electro-mechanical distributor with its pints and condenser. My car is so fitted and has never failed to start, even in the coldest of weather, and run reliably. In fact the only distributor failure that I had was when the distributor drive gear lost its teeth. Fortunately, I had a spare distributor that my grandson brought out to me and I was running within 2 hours. The problem with electronic devices are that, when they pack up there is nothing you can do about it on the side of the road. At least with points you can usually do something to get running again. RE: Electronic ignition - AustinWood - 12-01-2026 I have always carried a spare distributer under the back seat. I had to use it when the original DS4 distributer stopped working. The spare was a DK4a which I still carry. However the mechanical condition of old DK4s is usually poor at best. The Accuspark works a lot better from that aspect. RE: Electronic ignition - David Stepney - 12-01-2026 (12-01-2026, 10:18 AM)AustinWood Wrote: I have always carried a spare distributer under the back seat. I had to use it when the original DS4 distributer stopped working. The spare was a DK4a which I still carry. However the mechanical condition of old DK4s is usually poor at best. The Accuspark works a lot better from that aspect. Both mine have been rebuilt. RE: Electronic ignition - andrew34ruby - 12-01-2026 (11-01-2026, 11:07 PM)David Stepney Wrote: The problem with electronic devices are that, when they pack up there is nothing you can do about it on the side of the road. Throughout the 1980s and 90s I fixed dozens of electronic ignitions at the side of the road. If you carry a spare electronic module it could usually be fitted and working quicker than fitting a new set of points. Not that I have ever been a fan of electronic ignition, and I run both of my old Austins on points and condenser. RE: Electronic ignition - AustinWood - 12-01-2026 Before electronic ignition became the norm on modern cars the majority of roadside call-outd to AA, RAC etc was for ignition faults. With electronics they either work very well or don't work at all. There isn't a degradation of performance with use. Changing an electronic module is bery simple. They are held in by two screws and have two wires to connect. It doesn't usually affect timing either. RE: Electronic ignition - Charles P - 12-01-2026 I have a brand new Mallory dual point distributor that I quite fancy trying, largely because it has an easily tuneable advance curve. That's about as high tech as I go. RE: Electronic ignition - Parazine - 12-01-2026 I had to fix a Box saloon for someone local to me a few years ago; it had been standing in the garage for a long time an wouldn't run. I eventually found that the electronic ignition refused to work if the voltage on the unit fell below 5V. As the battery was going down to 4.8V cranking, even after a long charge - it wouldn't start. I suggested a new battery but the owner was reluctant as the existing one cranked the engine quite quickly at 4.8V. I converted the car back to points and condenser - problem solved! |
