Somebody else’s problem……. - Printable Version
+--- Thread: Somebody else’s problem……. (/showthread.php?tid=10066)
Somebody else’s problem……. - Denis Sweeney - 09-06-2025
Hi folks, today I was introduced to new A7 owner who has recently purchased a running Opal of late 36 vintage. He did not have the car with him but came with a neighbour firstly to meet me and see my Ruby and secondly to query me regarding problems he is having with his gearbox.
My neighbour had seen and heard me for many years restoring Ruby and had obviously told him I must be “in the know” ……………nah!!
He has a few issues he wants to sort but the main problem is that he cannot engage any gear without crunching the gears right from first through to 4th and including reverse and this is making it difficult to take it out on any runs.
He is not a dummy with respect to driving as he is a driving test instructor’s instructor and was telling me how he could change gears on Lorry’s without using the clutch, something I had witnessed first hand myself in years gone by.
So he is going to bring his Opal to me in due course for me to drive it so see if it is him or if I cannot drive it, what could be the problem??
I know I did strip and rebuild Ruby’s gearbox, following closely Woodruff and touch wood it has been no trouble since but I am not good at diagnostics.
Can anyone suggest “things to check” for when he brings his car, any information gladly received.
He has already joined the A7 Owners Club and I have recommended that he joins the forum and given him a list of useful stuff to beg steal or borrow.
Cheers for now
Denis S
RE: Somebody else’s problem……. - Chris KC - 09-06-2025
Could it be that the clutch is not disengaging properly?
RE: Somebody else’s problem……. - John Cornforth - 09-06-2025
These are the classic symptoms of clutch drag. Firstly, check that there isn't a wodge of carpet under the pedal restricting its movement. Secondly, you might be able to get a tad more disengagement by re-setting the lever on its shaft. It's held by a pinch bolt which needs to be tight. Beyond this it's a case of clutch overhaul to tackle the effects of wear.
RE: Somebody else’s problem……. - AustinWood - 09-06-2025
A high tickover will make it impossible, if the tickover is low it will ease things.
RE: Somebody else’s problem……. - Dave Mann - 10-06-2025
I had a similar problem decades ago and on dismantling the clutch I found the fulcrum point for the toggle levers 'repaired' by riveting in some 1/4" bar needless to say use removed the riveting and pushed the repair pieces out. This necessitated an interesting driving technique of never stopping in neutral and stopped at traffic lights with the handbrake hard on.
