Threads on dizzy shaft - Printable Version
+--- Thread: Threads on dizzy shaft (/showthread.php?tid=10062)
Threads on dizzy shaft - Erich - 08-06-2025
Hi All,
This is more a question out of curiosity. On my DJ 4, it appears I have a DK 4 shaft, though I am not totally sure of this. I would not be surprised if it had been changed at some point. Above where the drive gear is pinned, there are threads cut into the shaft. I see no threads cut into the housing the shaft fits into and am wondering if the threads on the shaft are cut to feed oil/grease to the drive gear. Any thoughts?
Erich in Mukilteo
RE: Threads on dizzy shaft - Tony Griffiths - 08-06-2025
Hello ERRic,
I've looked at three of the DJ4 type, and none have a thread above the gear. Nor do three of the earlier DS4 - or the single spare a DK4 I have. Might you have a photograph or two of yours?
RE: Threads on dizzy shaft - Erich - 09-06-2025
Hi Tony,
Here is a photo of the shaft on a page from the Austin Seven Centre Catalogue. I know that there inaccuracies in it as I found last summer. I have not found other exploded diagrams of the dizzies...Woodrow doesn't have anything. In the diagram, the DK-4 is on the left and the DJ-4, the earlier dizzy is on the right.
At the top of the photo is the shaft.
Best, Erich
.jpg   dizzy 1.jpg (Size: 117.1 KB / Downloads: 168)
RE: Threads on dizzy shaft - Chris KC - 09-06-2025
It's an oil scroll - I think you will find the opposite pitch on clockwise vs anti-clockwise shafts.
RE: Threads on dizzy shaft - Tony Griffiths - 09-06-2025
Ah! The scroll hidden inside the housing (not visible on the assembled unit I viewed).
RE: Threads on dizzy shaft - Dave Mann - 09-06-2025
Ah a scroll to attempt to keep the oil in the bearing instead of running out.
Yes, as I suspected, an oil scroll. The earlier DJ 4 shaft does not have one, so when they developed the DK 4, they added one. I'll note that in the drawing, it may appear that the DK 4 is made to use oil to lubricate the bearing and the DJ 4 only uses grease.
Thank you all for the replies.
Erich
