APD Tourer hood frame - Printable Version
+--- Thread: APD Tourer hood frame (/showthread.php?tid=10061)
APD Tourer hood frame - Belinni - 08-06-2025
Another hood frame question.
My APD military tourer is missing its hood & frame. Can anyone please post of photos of how this should be fixed to the body and what if anything it rests on?
Many thanks.
RE: APD Tourer hood frame - Tony Griffiths - 09-06-2025
It might help you to see if contact with this owner can be made. https://www.austin7.org/OtherArticles/MilitaryAPD/MilitaryAPD.html
The set of pictures here might help: https://vandp.net/sales/1505/1934-austin-seven-apd-militar...  (though many of the Military bits appear to be missing).
Can the hood frame possibly be any different to that of the ordinary APD?
RE: APD Tourer hood frame - Belinni - 10-06-2025
Thanks Tony, I had seen those. Ideally I'd like to see a couple of up close shots of the hood fixing to the body - yes I can't see there being any difference to a standard PD tourer. (with respect to the hood fixings).
RE: APD Tourer hood frame - Ruairidh Dunford - 10-06-2025
The blue car in the photos is actually a car supplied to the War Dept. around 1937/38 It's not really very different to a standard model but does have evidence of using up some of the old stock parts (not unlike the vans of that time) along with the later running gear, notably the fuel sender on the font tank, Girling brakes and axles on a high frame chassis, 17" wheels, Ruby steering wheel, column and instrumentation on an earlier dashboard.
These are often incorrectly described as "Military Tourers" - which are quite a different beast, as shown in the other link to Andrew Jarmin's pukka one.
