Hand brake gaiter - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Hand brake gaiter (/showthread.php?tid=10050) |
Hand brake gaiter - Erich - 05-06-2025 Hi All, I realize this quite a bit of rivet counting. On the Ulster hand brake gaiter, does the seam end up on the O/S or the N/S. The O/S seems to be more logical. Any thoughts? Erich in Mukilteo RE: Hand brake gaiter - stuartu - 05-06-2025 Erich, I do not know the answer, alas, but venture to suggest that perhaps one might put the seam at the front and then nobody's nylons would suffer. Just an idea. All the best, Stuart RE: Hand brake gaiter - Erich - 05-06-2025 Thank you Stuart. As the gaiter which has been copied from the old one has the seam on one side, rather than at the front, I don't think I can turn it around. As well, the curve and the front(or rear) is difficult as the material bunches up there as it turns the bend so to speak. I've used the lightest vinyl I could find, but the backing is the issue as all vinyl seems to have a fairly heavy backing. Upholstery seems to be my achilles heel! Erich in Mukilteo |
