1933 AH Tourer hood frame - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: 1933 AH Tourer hood frame (/showthread.php?tid=10043) |
1933 AH Tourer hood frame - GM6VXB - 04-06-2025 Wonder if anyone has seen a diagram for the hood framework on a 1933 AH tourer. Not totally convinced the hood frame has been put together correctly. Goes up and locks ok, but does not go down far enough to fit the cover even if you push it down hard. Slightly suspicious one of the arms has been fitted incorrectly, but before I start taking the frame apart just want check. Had a search but not found anything (yet). Will try to take some pictures later but need the car outside and it's looking like rain. Martin. RE: 1933 AH Tourer hood frame - Tony Griffiths - 04-06-2025 Are you pulling all the hood material out, laying it backwards and then folding over the top before fitting the cover? The hood instructions are the same from the first to the last edition of the handbook, though later ones omit the illustration. Unfortunately, there are no hood frame drawings in https://archive.a7ca.org/collections/technical-drawings/ RE: 1933 AH Tourer hood frame - GM6VXB - 04-06-2025 Tony, Yes, all done as per the manual. Maybe the attached picture (sorry about quality) helps. The manual shows the bottom arm to be near horizontal. From my picture, the arm is definately not horizontal. Maybe the rubber stop toward the rear of the car is the problem being too thick. Possibly removing the rubber completely might help but know the fixing bolt is siezed and rounded so will have to be drilled out. Will look into this tomorrow, but, now look at the rest of the frame arms. They are definately not as per the manual, pointing up at the front. The only way to get them to look like the manual is to push them down hard. They spring back up when released to the position in the photo. The canvas hood is not jambing into the framework, presently the hood is hanging down the back of the back of the car and I have checked nothing else is jambing. Looking at the hood frame, there are no obvious bends in any of the arms, unless both sides have been bent the same ?. Reading both the old and newer manuals, they refer to fixing the hood frame to the hood rests by means of fasteners. My car does not have any sign of fasteners, or holes where they might have been. So confused, but wife is away tomorrow so will spend time seeing if I can figure out what is wrong. Martin. Sorry about the picture appearing upside down. It was the right way when I posted it !!. RE: 1933 AH Tourer hood frame - "Slack Alice" Simon - 04-06-2025 That doesn't look right. I will take a picture of mine tomorrow, you can compare, and maybe see where the problem is. The manual refers first to fasteners by the rear window - which I don't appear to have. The second fastemers are on the cover, not on the frame or the hood - these I have. The clip mentioned is what you tuck the frame into when you fold it down first, it is just a square U shaped bit of metal, lying on its side, open ends towards the body. I will try and show these details on pics tomorrow. Apologies, I keep going back and forth between your picture, the handbook, and my replies. The rubber on your frame rests is too big. It should be almost no thickness at all. - my car has lost the original rubbers, and there is just metal to metal - I mean to put a bit of leather or rubber there, and keep forgetting. RE: 1933 AH Tourer hood frame - GM6VXB - 05-06-2025 Well, I have removed the rubber buffers (pig of a job) and the hood now sits with the rearmost frame bar horizontally onto the support. So this is now looking more like the handbook pictures. Only problem now is the rest of the frame does not fold down as low as shown in the manual. I have found what might be some adjusting bolts which might cure this but my back is aching so stopped for now. An added bonus is the hood cover now (nearly) fits correctly. All the upper 'DOT' fasteners now click nicely into place, but the press studs to hold the bottom of the cover won't click on as the hood folds down over them. Bit more fettling to do but happier with the hood folded down now. Thanks all, Martin RE: 1933 AH Tourer hood frame - "Slack Alice" Simon - 05-06-2025 Pics of the hood frame at rest, megapixels reduced I have more, let me know if you need more. Cheers, Simon RE: 1933 AH Tourer hood frame - Tony Griffiths - 05-06-2025 This is the arrangement of the hood and support bracket on my 1930AF. Looking at yours, might you need to lift it up at the back and then use an extra leather strap to tie the various bars more tightly together? This is the sort of rubber block I used to make the support. RE: 1933 AH Tourer hood frame - GM6VXB - 06-06-2025 Thanks for the picture, explains a lot to me. I have found where the side tiedown straps should be. Both missing, but as the hood has a strap fitted centrally to hold it down I will stay with this. I have now used some sticky back closed foam strip for the hood frame support. Works well and will stop anything rubbing badly. Still got part of the frame not sitting correctly when down, but it is pretty close to the pictures so will leave until winter and will take the complete hood off and do some more work on it. Does need a re-paint so might see if I can get it powder coated. The hood cover now fits very well, and using the centre strap should not blow off on a windy day which we get very often here. Off to do some other jobs before I attempt the 150 mile trip to Guildtown at the end of the month. Martin. |
