Clutch linings - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Clutch linings (/showthread.php?tid=10009) |
Clutch linings - Mick Hanna - 24-05-2025 I recently bought a clutch kit from the online auction site we all know. It was listed for a late Ruby. The only problem is that the clutch lining is incorrect for any of the Rubies (Borg and Beck/Newton-Bennet. I should have spotted this from the pictures. It appears to be the earlier kind that attaches to the flywheel, possibly the Box saloons (2 Bearing engine 1933-36) and maybe even common to all sevens from 1923-1932? I would like to move them on to somebody who might be in need, rather than sticking them in a drawer where they may not see the light of day again. To sell the linings accurately and with confidence can anybody confirm the dimensions of these earlier linings? These measure 8 1/2 inches outside diameter and 6 1/2 inch inside diameter and come with 12 short and 12 long rivets. RE: Clutch linings - Mick Hanna - 27-05-2025 I thought I'd bump this back up to the top as I haven't had a response yet, nor on Facebook, and I still need to identify size and fitment. Thanks. RE: Clutch linings - bystander - 27-05-2025 I can confirm pre-1936 flywheel-fitted linings are 8-7/16" od x 6-1/2" id, with 12 equally spaced rivets. I believe very early type are only 6 holes per lining, but these will stillĀ fit, using every other hole. The original part number is 1/AT/2, but I'm pretty sure these are relatively recent manufacture, so probably asbestos-free. RE: Clutch linings - Mick Hanna - 27-05-2025 Thanks Bystander. That is exactly what I need to know. I can now move them onĀ to somebody else with confidence.
