Electronic Distributor - Printable Version
+--- Thread: Electronic Distributor (/showthread.php?tid=2822)
Pages: 1 2 3
RE: Electronic Distributor - theprisoner - 03-09-2019
FET = Field Effect Transistor, power ones are referred to as HEX FETS name due to construction in the silicone. They are a voltage controlled device like a Thermioniic valve. You raise the gate voltage to a certain threshold and the Drain Source junction begins to conduct.
