fuel gauge - Printable Version
+--- Thread: fuel gauge (/showthread.php?tid=9941)
Pages: 1 2
RE: fuel gauge - GM6VXB - 11-04-2025
Picture of the guage on a 1933 Tourer.
On the 'must get round to giving it a clean' list !.
Martin.
RE: fuel gauge - John Cornforth - 11-04-2025
Hello again Dave
Judging from the photos, you have a Smiths "Bimetal" gauge, vintage late 1950's onwards at a guess.  These work by the heating effect of a small resistor which bends a bimetal strip to move the pointer. They thus respond rather slowly. The gauge is wired in series with a variable resistance tank sender, nominally 70 to 300 Ohms. This is much higher than the 3 to 25 Ohms of an original 1930's Smiths/Austin 7 sender which was paired with a "moving iron" style gauge.  Bimetal gauges are not polarity sensitive so can be wired either way round. The earth (case) connection is only used for the backlight bulb. The individual round gauges (rather than clusters) tended to be used by lower volume car makers or for aftermarket applications.
These bimetal gauges run from 12 volts but usually via a voltage stabiliser to stop the readings varying with charging voltage. Such stabilisers were also based on bimetal principles, and turned on and off at a slow rate to give an average output equivalent to about 10 volts. Modern replacements are solid state.
More detail in the attached article.
