3 Bearing oil tube nut removal - Printable Version
+--- Thread: 3 Bearing oil tube nut removal (/showthread.php?tid=9117)
Pages: 1 2
RE: 3 Bearing oil tube nut removal - Jeff Taylor - 14-01-2024
wild_willy,
Details of the dimensions / shape of a suitable cranked spanner can be found on the 'Cornwall Austin Seven Club' site.
https://www.austin7.org/Technical%20Articles/Oil%20Feed%203-bearing%20eng/
RE: 3 Bearing oil tube nut removal - wild_willy - 15-01-2024
The pipe oil nut is positioned very close to the oil mesh flange which means a ring spanner of socket cant be used. I will attempt to thin down and shorten a ring spanner to see if that works.
Thanks Jeff for the reference to the Cornwall site. Very informative.
Again thanks to all who contributed.
Bruce Shearer
