| The following warnings occurred: | |||||||||||||||
camshaft locating bolt - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: camshaft locating bolt (/showthread.php?tid=6459) Pages:
1
2
RE: camshaft locating bolt - SneezerUSA - 05-08-2021 MY ERROR. on the fiber dynamo drive gear. I assumed the the English version of the gear would be the same as that of the American Austin gear. I was obviously incorrect. The attached is a photo of the chewedup fiber gear. The hole in my motor case was elongated allowing the bushing and camshaft to move forward destroying the gear. I'll try later to forward photos of my repair method. RE: camshaft locating bolt - SneezerUSA - 05-08-2021 Starting to think I am brain dead on getting my dynamo fiber gear reply posted. My error in indicating that I had the fiber gear fail was based on the assumption that the Austin 7 motor had the same material as the American Austin motor. This was incorrect. My motor had the fiber gear but the replacement gear I robber from another motor was steel. A photo of the destroyed gear is attached. The hole for the bushing locating bolt on my motor was elongated allowing the bushing and camshaft to move forward destroying the gear. I will try to forward [photos of my repair method later RE: camshaft locating bolt - Bob Culver - 05-08-2021 With the inherent sliding with a cross gear, an odd choice of mterial. |
