Engine Block Replacement - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Engine Block Replacement (/showthread.php?tid=4812) Pages:
1
2
RE: Engine Block Replacement - Bruce Nicholls - 18-08-2020 All four rods were cracked at the pinch bolt on my RP when I acquired it in 1971. RE: Engine Block Replacement - cwchrisp - 18-08-2020 Much to consider, so thank you again! I will keep this post and consult Woodrow again, keeping a list of all the tasks and order of work ready for winter. It doesn't seem such a daunting task having read the replies here! All my plugs were oiled up yesterday and the piston crowns I could see were well coated. Chris RE: Engine Block Replacement - Bob Culver - 18-08-2020 It is curious that so many conrods are apparently fretting at the gudgeon hole. With the small pinch bolt subject to a repeated cycles of loadng would expect fatigue failure. Apparently seating of the bolt deteriorates so rapidly that movement of the eye can occur unrestrained. (A local member with a 6 had a rod split full length. It was welded to repair!) RE: Engine Block Replacement - Dave Mann - 19-08-2020 Having just acquired yet another good crankcase with all threads sound, front lip intact and no cracks but it had been sandblasted and left for a few years. After removing all the oilway plugs I spent an hour with a pressure washer and washed a pile of sand out of it. This revealed enough sand for a play pit and the top face was heavily fretted at the front and rear nearside corners which is why a lot of Sevens leak at this joint. By the time I'd trued the face up the number had almost. disappeared. |
