| The following warnings occurred: | |||||||||||||||
Valve pins - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Valve pins (/showthread.php?tid=10526) Pages:
1
2
Valve pins - Peter Naulls - 20-12-2025 Can anyone tell me what grade steel I should use for making valve pins? and a likely supplier? The cherished supplier I got my new valves from some weeks ago is not able to get pins. The ones I took out of my old valves are 5 thou too big and some that I bought from another supplier are 10 thou too big! I need 0.1" diameter. RE: Valve pins - john williams - 20-12-2025 When you know the diameter you need, go to your local cycle shop and buy a spoke of the same diameter. This is what I was taught as an apprentice 1957/1960s. John RE: Valve pins - Robert Leigh - 20-12-2025 0.1" seems large compared with what I have used in the past. My present cars do not have pins so I can't check. RE: Valve pins - AustinWood - 20-12-2025 I seem to remember using a cut down panel pin 65 years ago which worked with no problem! RE: Valve pins - David Cochrane - 20-12-2025 Wouldn't it be simpler just to buy them from a cherished supplier? A7 Components have them in stock at the correct original size. RE: Valve pins - Peter Naulls - 20-12-2025 Thank you David, I did check your website and at the time I ordered the pins were out of stock with you, hence I ordered them from the Seven Workshop who's website wrongly showed that they were in stock! What diameter are the ones you have? RE: Valve pins - Ivor Hawkins - 21-12-2025 On my Austin Ten, I used the needle rollers from an old Hardy Spicer universal joint…worked a treat! RE: Valve pins - Peter Naulls - 21-12-2025 Thank you Ivor, I have some of those so certainly worth having a look. Otherwise I'll see if David can help. RE: Valve pins - robert regan - 21-12-2025 the shaft of a pop rivet is a good option and enjoy your Christmas before its completely banned by the supermarkets and the Government Regards to all Rob. RE: Valve pins - Peter Naulls - 22-12-2025 Thank you Rob, I have a box of those too so plenty of options to look at after Christmas. I'm sensing from the many and varied suggestions that the type of steel doesn't matter - I can't imagine that bicycle spokes, pop rivets and needle rollers all use the same stuff
