  • 1 Vote(s) - 2 Average
Magneto starter dogs
All,
Where can I obtain a new starter dog for a magneto engine. I am fitting a new Barlow crank and the standard dog plain section is to long ( I know this is an issue for Phoenix cranks).
Thanks
I turn mine down slightly - they only need a small amount on material removed.
I have some pictures on the old Forum explaining how to do it but will need to see if I can locate them...
Found the photos...
Original dog...
.jpg   Original Starter dog copy.jpg (Size: 198 KB / Downloads: 213)
Front of Phoenix shaft...
Turned down dog...
.jpg   Starting handle dog after copy.jpg (Size: 195.5 KB / Downloads: 213)
Is this just a problem with magneto engines. Two years ago I fitted a phoenix crank to my Ruby engine (coil ignition). The only difference I found was the starting handle was in a slightly diffrent position when at rest.
John Mason.
(17-02-2018, 05:30 PM)John Mason Wrote: Is this just a problem with magneto engines.
Yes.
