  • 0 Votes - 0 Average
broken cylinder head stud
I remember using an extractor bit many years ago to good effect. Leaving plenty of meat in the stud to be removed means they reduce the risk of damaging the female thread. Worth a try in the first instance I'd have thought.
See [Only registered and activated users can see the links Click here to register]
(12-11-2017, 10:37 AM)Colin Wilks Wrote: [Only registered and activated users can see the links Click here to register]
I've never known one of those extractors work on an old stud that's broken through seizure
hi all
going to dry drilling pilot hole today, thank you for the pdf, will come in usefull, yes the stud was a old rusted one, but i probably should i realised i was exerting a little to much force. will keep you updated, but thankyou for your help what ever the outcome
If put the head on as a guide spot the end of the stud with the largest drill that will go down the hole.This will give you a centre.then drill down through with say a 5 mm drill ,if you have a helper get them to "eye up" that you a still drilling square.
Check that the drilling you have made looks central,if so ,with or without the head on drill out to 6.8mm.
If the hole is true you should have reduced the stud to a spiral down the hole.
With a plug tap try to pick up the existing thread,this is where it gets tricky,sometimes I've used a tiny chisel to pick up the start.You have to be really careful,bit at a time.
If all else fails providing you don't break the tap in it,you can helicoil it back to size
When removing rusted head studs I try to shock them to free them up. I do this by dropping the head onto the engine and then hammering the stud as if it were a nail. I put the head in place to help avoid bending the stud.
Shocking studs this way often loosens them.
Hello Ollie
Whereabouts are you. Do you know of anyone with a TIG welder.
Welding a nut to the broken stud, or if it has sheared off flush, build up the stud with weld and then add a nut.
This method has never failed to get the stud out. Welding causes the stud to shrink and loosen itself.
Adrian.
(11-11-2017, 06:37 PM)Jeff Taylor Wrote: [Only registered and activated users can see the links Click here to register]
Thanks Jeff.
(11-11-2017, 01:58 PM)AustinWood Wrote: I guess the old one snapped taking it out.
whilst putting new cylinder head studs in.....one stud snapped flush with the block
I take your point Austin but not quite what the OP said....perhaps I'm being pedantic again!
There is a tool called a stud extractor you could use, bit like a tapered left handed tap, drill a hole in the centre of the broken stud, put point of the extractor in the hole and turn anti-clockwise. The extractor will bite into the stud and wind it out. I did lots of these when I as an engineer. Cheers. Burky
