  • 10 Votes - 4.2 Average
Gallery
#31
There wouldnt be any sparks Andrew. The fire is well insulated from the world at large by 30odd 6foot (ish) long 1 1/2 diameter firetubes and the chimney which also has a cap on it.
(03-01-2019, 07:20 PM)andrew34ruby Wrote:
(03-01-2019, 01:55 PM)Hedd_Jones Wrote: The caption is self explanatory. Anyone know the pub if it is still there?
the steamer looks likely to be a Burrell 5 ton tractor, probably pre 1910. Hauling timber on a pole carriage, and has been banked up for the night.
AD tourer. 1928/9?
[Image: 008_1712.jpg]
A smoky, sparky, coal fire in the traction engine --- next to a thatched roof!
One of my early haunts of the 1960's. Still there, changed a bit though.
Hello Hedd.
We have seen sparks coming out the chimney at the Great Dorset Steam Fair. Maybe just putting on a show!
[Only registered and activated users can see the links Click here to register]
Adrian.
(04-01-2019, 02:03 PM)Adrian Payne Wrote: [Only registered and activated users can see the links Click here to register]
Adrian.
The exhaust steam goes into the bottom of the chimney, creating a vacuum behind it, thus 'pulling' the fire. The harder the engine works, the harder it pulls the fire. The 'puffer' principle.
But a steamer is direct drive, no clutch, so if the engine is stationary, no exhaust to pull the fire, certainly no sparks. Particularly if there is a damper on the chimney.
An engine working very hard will throw sparks, at the GDSF there is a lot of showing off so you will have seen it (as have I). In real use you try to avoid it for obvious reasons, we generally carry £5,000,000.00 insurance policies against damage caused by sparks. And have to fit 'spark arrestors'. Its not at all difficult to drive in such a way where they are minimized. There was a lot of discussion on various groups on Facebook over the summer about this given the dry spell we had.
