  • 0 Votes - 0 Average
big seven gear stick
Hi.
Big seven gear stick when in neutral wanders side to side.. You will know that it a long stick with a bend half way up, that seems to make the wander more so!!  Any ideas how this could be sorted,by someone who knows little of these jobs?  Thanks for any input..
Arthur
Arthur, before you fix it are you sure it's broken? I've never been in a Big Seven but an A7 lever has about a mile of free travel - perfectly normal.
Big Seven gearstick is identical to a normal 4 speed sycnchromesh "Baby" Seven gearstick bar the small recess for the circlip that secures the chrome gear position plate.
In fact, the internals of the gearbox, except the first motion shaft are identical also. The casing is a different casting.
