06-10-2019, 06:32 PM
Any ideas on this part ?
06-10-2019, 06:43 PM
We discussed something similar under rear springs. It looks like the spacer you need on top of the rear leaf springs when reducing the number of leaves. This stops the u-bolt bottoming out in the slot and keeps the head of the nut in the hexagonal hole in the chassis rail.
07-10-2019, 02:32 PM
Found it,Many thanks Nick
Strange only to have one but once it all goes back together I guess I'll quickly find out if another is needed :-) Now on the look out of the cross shaft correct layout ! cheers Matt |
