Lucas Graves headlights (1931/32)
Can anyone confirm if the internal sidelights on these were at 6 o'clock or 12 o'clock?
My car has them at 12.00 o'clock in which position the headlamps work fine and dip as they should.
Sidelamps on. The offside headlamp is a different pattern and has the sidelamp bulb within the reflector rather than behind it under a window.
.jpg   S013I001.JPG (Size: 129.15 KB / Downloads: 156)
Both should be at 12.00 o'clock. bulb holders my vary though.
Regards from the creative county - Staffordshire
Stuart
Thanks
