Chummy length?
Would a chummy or early box saloon fit in my garage sideways?, the garage is 103 inches wide ( 8ft 7 inches).
6'3" plus 2 off at half 19" (half a wheel) plus 2 off at 3.5" (tyres) = 101" plus however much the mudguards stick out.
Mudguards are removable, though.
You will need at least 9' 8" of space for a Chummy - depending on what rear lights you have fitted.
Thanks for replies, that idea is not going to work then.
So you can't have two, but you can have one lengthways and still have additional space for a jacuzzi or an engine crane.
Much easier to get it out then too, through at least one of the ends.
...if you park two nose-to-nose you can overlap the front wheels and they take up less space ...
How high is the ceiling?
The ceiling height is 9ft.
it might fit sideways diagonally.
Ill get my coat
.jpg   possible.jpg (Size: 261.46 KB / Downloads: 151)
Possible in desperation? (I'm not kidding...)
