  • 0 Votes - 0 Average
Tyres in Aus
I am at the stage where I need replace the 30+ year old rubber on the Arrow, (19 inch wheels). Longstones, although highly recommended, cost more to ship to Western Australia than the purchase price! Can anyone in Australia recommend a more local source of good tyres.
(05-01-2019, 01:15 AM)Mark Dymond Wrote: I am at the stage where I need replace the 30+ year old rubber on the Arrow, (19 inch wheels). Longstones, although highly recommended, cost more to ship to Western Australia than the purchase price! Can anyone in Australia recommend a more local source of good tyres.
Avon Sidecar 3.50 x 19 Tyres are usually the easiest to find locally (flat tread) - check local tyre importers or the WA A 7 Club re stocks in Aust. Don't quote me but should be available for around A$1000 for 5 tyres c/w tubes and rust bands.
can't find a Longstone supplier in Australia but there are suppliers of 400x19 tyres [Only registered and activated users can see the links Click here to register]
they stock 3.50 x 19 as well [Only registered and activated users can see the links Click here to register]
(05-01-2019, 06:42 PM)Michael D Wrote: [Only registered and activated users can see the links Click here to register]
Fairly sure there's a Longstone agent here in Melbourne and if correct I think it's run by an ex-Kiwi I know, so will chase up and advise if yes or no re Longstone.   Cheers,  Bill in Oz.
(11-01-2019, 12:01 AM)Bill Sheehan Wrote: [Only registered and activated users can see the links Click here to register]
You may try to find these: [Only registered and activated users can see the links Click here to register] They are around $150 ea. here (US). I found them looking at this one [Only registered and activated users can see the links Click here to register] as a possible fit for my Ruby with 16" Export wheels. On an unrelated note, what size tire was supplied on export Ruby's ? I find 5's that look too big and 3 1/2's that look too small. Mike
Oops, I just followed the link above to the Heidenau's.
"On an unrelated note, what size tire was supplied on export Ruby's ? I find 5's that look too big and 3 1/2's that look too small"
Mike,
According to my 1948 Dunlop Catalogue covering cars built between 1934 and 1947, the tyres on the A7 16" Export wheels were 4.75 x 16. Longstone Tyres here in the UK can supply a Firestone 450/475 x 16" at £168 + VAT
Spec is:
Type: Crossply
Rim Diameter: 16" (406mm)
Actual Width: 4.7" (121mm)
Overall Diameter Inflated: 26.18" (665mm)
Weight of Tyre: 5.8 kgs
(11-01-2019, 12:57 AM)Jeff Taylor Wrote: "On an unrelated note, what size tire was supplied on export Ruby's ? I find 5's that look too big and 3 1/2's that look too small"
Mike,
Spec is:
Type: Crossply
Jeff, thank you ! Wow, almost $900 ! that's like 3 sets of tires for my wife's car. Going to be a hard sell. Especially when one adds postage. I think I'm still looking around. Smile Mike
(11-01-2019, 01:10 AM)FrogPond Wrote:
(11-01-2019, 12:57 AM)Jeff Taylor Wrote: Mike,
Spec is:
Type: Crossply
Goodness-  not sure what your wife drives- a set of four good quality tubeless tyres for the VW Tiguan will cost A$1,000 in Australia,  the same price as 5 Avon Sidecar 3.50 19's with tubes for my Seven.
Cheers, Tony P.
If you email Longstone I'm sure that they'd tell you if there's source in Australia,
Charles
Thanks all, Ive emailed Longstone regrading options and Ill compare to the price of the Avons locally - cheapest wins.
I assume the sensible next step is to measure the runout on the rims. I'm thinking I could measure this by mounting each wheel to a rear hub with the car on axle stands.
What sort of runout is considered acceptable, hints relating to technique from the wise and experienced appreciated .
