Thanks Zetmagneto! For your input. So are there at least 3 variants of the Lucas panel?
I thought coil cars had the panel with the charge light?
And Magneto cars had the dash plug sockets? But perhaps there was a crossover?
I think I’ll check the wiring with a battery and a bulb
To see how this one works.
Bill G
Hi Mike
Thanks for the helpful input, there is a plug in the
Auxiliary pair of sockets.
Thanks too for the info on the cut out connections.
Looking at the rear of your coil panel is different
But just to check? Are you saying “correct” means coil type!
So there 3 types of SM panel...?
Bill G
Car type: 1928 Mulliner Fabric Saloon
I was going to say as it has summer and winter winter charge settings rather than M (magneto) and D (dynamo) it seemed to be coil, but wasn't certain. Looking at the back it certainly seems likely it's coil, mag type only has strip to lighting switch (and the socket).
A test seems the best idea to be sure of which it's for, fingers crossed for you.
As Timothy says, a mag-type switch panel should have M and D on the face. I beiieve Bill's panel is an interim unit between the normal mag-type and the coil type with ignition light, presumably fitted to the late coil-ignition R-Type saloons late 1928? A circuit test will establish whether the ignition switch is earthed in the on position for a magneto, or live for a coil.
19-12-2018, 11:35 AM
(This post was last modified: 19-12-2018, 11:36 AM by AllAlloyCup.)
Hi Mike,
Thanks for solving this mystery!
See EBay item 392195643465
Which currently wrongly listed as a
Coil switch panel it has the M and D
And the appropriate wiring on the back
as you described .
Bill G
