Great to see so many successes - what do you all use in the big ends? My preference to date is deep nylock and thick spring washer.
What else are folks using successfully?
It's a good job you weren't in the RK.
Just to be different I don't use spring washers, but I do use loctite and nylocs.
An engineer I very much respected told me years ago that correctly specified and tightened fasteners don't come loose. That's been my experience too.
As an aside, spellcheck interpreted loctite and nylocs as lecture and nylons ....... oh well.
Car type: 1932 RN saloon
If you have an hour or so to spare and look at boltscience.com website, especially the video "vibration loosening of threaded fasteners" you may be convinced that single coil helical spring washers increase the risk of your little end screws coming loose.
There appear to be two 'separate' plates clamped together in the test - does this and the vibration used replicate the situation at the little end?
03-09-2017, 09:17 PM
(This post was last modified: 03-09-2017, 09:20 PM by Ruairidh Dunford.)
Does Junkers' theory rely on minute movements (caused by vibration) between two separate surfaces to 'rattle' the screw and dislodge the grip of the spring washer?
