BESPOKE PETROL TANK
The material is now called Terne Plate II and uses zinc in place of the lead. I've heard original terne may still be available some place. A recent thread here, someone posted that Austin tanks were mild steel that were sealed with liquid solder. Would this have been the case or would terne have been used? The film of Austin rads being made, would indicate that liquid solder might have been used.
Erich in Seattle
(16-08-2018, 09:48 PM)Duncan Grimmond Wrote: think that Terne plate went out of manufacture completely about 30 years ago? I could do you steel or even a brass one!
That looks absolutely stunning, Duncan.
Are you serious about being able to do one for us?
That is gorgeous but you are going to need a hell of a big bottle of brandy to fill that hip flask...
Martin
http://www.alloyracingfabrications.com/
