pearl cabriolet
does anyone out there have a rear window frame for a pearl cabriolet available for sale,I have just acquired a very original but "scruffy"! car running and driving plus as a bonus it stops very well .There is no rot anywhere and the original interior is very usable and will be preserved it has had a new hood at sometime and  I think that was when it lost its window. could any owner of a pearl post the size of the frame and the height it sits from the top of the body best regards Rob.
Is it a mk1 or mk2 Robert?
its 1936 mk1 best regards Rob.
I will measure mine later for you Rob, I think it will be easy to shorten a Ruby glass to the correct dimensions.
16 1/2”  height and 17” wide.
Does he not mean the rear window not the side ones?
yes your right I meant the frame in the hood, thanks to all Rob.
Is a Mk2 window the same size as a Mk1, if so I have the rear glass out of mine somewhere.
If its any help I have the rear outer frame on the shelf in the garage, would it help you if I draw round it on paper ? Edit to add : mine is a MK2 but presume they are the same.
Sorry, I misunderstood.
The rear windows are very slightly different sizes between mk1 and 2.
However you can buy something that looks correct (and is very similar in size) here: https://www.vintagecarparts.co.uk/produc...ndow-frame
(09-07-2018, 11:47 AM)Nigel was in Brittany Wrote: Is a Mk2 window the same size as a Mk1, if so I have the rear glass out of mine somewhere.
mine is a mk 1 but if they are both almost the same size if I had the outer I can make the inside frame and the support bars and hinges the glass would be usefull as well ,I am on a landline number if you could tell me what you want for your items thanks to all Rob.   01495 222066.
