  • 0 Votes - 0 Average
Windscreen replacement
Ah-ha, I now realise who you are!
I thought I recognised the bonnet - it all becomes clear and I am certain you will work out a suitable solution, as you have with all the other 'required' modifications!
(10-06-2018, 05:21 PM)Scarlet O\Hara Wrote: The main reason I was going down the plastic route was that I suspect a new glass screen will fail in the same way as the existing screen which requires a cut out for the vacuum wiper where it has failed at the corners. Bigger radius corners required or I wonder if drilling a hole for the shaft rather than a full cut-out would be a better solution? Any other suggestions?
You could look at laser cut glass = no chips or micro fractures.
I would expect it to be more expensive that using a cutting wheel.
