Starting dog. - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Starting dog. (/showthread.php?tid=6221) |
Starting dog. - Russlin - 08-06-2021 Good morning All, My 1928 magneto engine has recently been overhauled and fitted with a 1 1/2" jet fed Phoenix crankshaft. I now find that I can no longer use my crank handle to start the engine as the starting nut as fitted to the Phoenix crank is worn. Pushing forward on the crank handle while turning it requires a super human effort to keep it engaged with the nut. The engine is free. The engine repairer advises that the original starting nut from my 1 1/8" crank cannot be used on the Phoenix crank and that the correct nut for the Phoenix 1 1/2" is unavailable. Any thoughts on whether: 1) The worn starting nut fitted to the Phoenix crank can be fettled to suit my 1928 crank handle, and 2) The nut can be removed from my engine for fettling without dismantling the engine ? Thank you. Russell. RE: Starting dog. - Alan - 08-06-2021 Are you sure it’s not simply that the crank handle is not properly aligned with the crankshaft dog? One of the things you have to do when you replace a mag engine is make sure the staring handle is properly aligned both side to side and up and down. RE: Starting dog. - leaf200 - 08-06-2021 Your engine repairer is wrong you can modify the original starter dog off your 1-1/8 to fit it’s a simple mod you need to do for any Phoenix crank RE: Starting dog. - Robert Leigh - 08-06-2021 If the 'teeth' of the starting dog are worn they can be built up by mig welding and grinding to re-profile. RE: Starting dog. - Ruairidh Dunford - 08-06-2021 I have no experience of pressure fed systems but this mod may be of use, others will be able to confirm: https://www.austinsevenfriends.co.uk/forum/showthread.php?tid=5041&pid=54870#pid54870 RE: Starting dog. - Russlin - 08-06-2021 Thanks Alan, Leaf 200, Robert Leigh and Ruairidh for your early replies all of which I found helpful. Russell. |
