Rear brake set up - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: Rear brake set up (/showthread.php?tid=4238) |
Rear brake set up - Youngseven - 23-04-2020 Hi all, I have a 1938 long chassis which was originally a van, and I am missing some brake linkage on the rear, can any one show me photos of the set up to show me what I am missing. Thankyou in advance. RE: Rear brake set up - Colin Morgan - 23-04-2020 Sorry, this isn't a great picture, but it shows the rod from the cross-member bracket, back to the rotating 'tree' mounted on the differential casing, and the two different length rods that then go through the back plates to operate the brakes. The various parts can be seen individually in the Spare Parts List No. 1586a - the last one in the list in the A7CA.org Archive - pages 46 and 50. Colin RE: Rear brake set up - Ian Williams - 23-04-2020 DSC05793.jpg (Size: 257.27 KB / Downloads: 197) RE: Rear brake set up - Youngseven - 23-04-2020 That is perfect, Thankyou very much for both of your help. RE: Rear brake set up - Chris Garner - 24-04-2020 I've sent you a PM. Best. Chris, |
