Helical gear for oil pump - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Sales & Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=9) +--- Forum: Wants (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=11) +--- Thread: Helical gear for oil pump (/showthread.php?tid=3266) |
Helical gear for oil pump - Roger - 01-09-2019 I am looking for a good oil pump drive gear, are they available from cherished suppliers? I have looked but not seen any advertised. It’s for a 1933 RP but I guess they are all the same.. Roger RE: Helical gear for oil pump - Zetomagneto - 01-09-2019 I have a good spare.pm me RE: Helical gear for oil pump - Ruairidh Dunford - 01-09-2019 Roger - these are readily available and, almost always, in good condition. Happy to send you one for the cost of the postage. RE: Helical gear for oil pump - Zetomagneto - 01-09-2019 Yes they survive well, I have a lot of them, but not as many as Rory RE: Helical gear for oil pump - Roger - 02-09-2019 Thank you both for your replies, I will send pm Ruairidh. The crankcase and cam shaft are totally corroded beyond use, I did remove the oil pump but the gear I needed was worn/corroded on one side, I have plenty of pumps though. Roger |
