SU carb. - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: SU carb. (/showthread.php?tid=2103) |
SU carb. - jonblob33 - 09-12-2018 Hi, having just acquired a H1 carb I am thinking about fitting it to my bog standard 1933 PD. The carb has a weighted piston & no spring. Can anyone suggest a safe starting point for needle & jet please? Also could I fit a spring with the weighted piston. TIA. Kevin. RE: SU carb. - Jeff Taylor - 09-12-2018 (09-12-2018, 09:27 PM)jonblob33 Wrote: Hi, having just acquired a H1 carb I am thinking about fitting it to my bog standard 1933 PD. The carb has a weighted piston & no spring. Can anyone suggest a safe starting point for needle & jet please? Also could I fit a spring with the weighted piston.Hi Kevin, See link below to my recent post 25th November on this subject - mine is post number 6. I can't see any reason why you would want to fit a spring as a weighted piston carb never had one. The jet should be the standard 0.090". http://www.austinsevenfriends.co.uk/forum/showthread.php?tid=2041&pid=19712#pid19712 Jeff. |
