phoenix cranks - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: phoenix cranks (/showthread.php?tid=1883) |
phoenix cranks - Steve Clare - 14-10-2018 I am looking for an 1 1/8 phoenix crank for building a spare engine for my 27 chummy. Although not known for my patience, I will wait in the queue, but if anyone has one they would consider selling, please give me a shout. Apparently an 1 5/16 will also fit, but I'm guessing that this would involve quite a lot of mods? I am not going racing- mainly to the off- licence and back. RE: phoenix cranks - Peter Johnson - 14-10-2018 Have you tried David Cochrane (A7 components)? Peter RE: phoenix cranks - Zetomagneto - 14-10-2018 (14-10-2018, 07:29 PM)Steve Clare Wrote: I am looking for an 1 1/8 phoenix crank for building a spare engine for my 27 chummy. Steve, hardly any modifications to fit the 1 5/16 crank and a much better prospect . You would need later main bearing housing, and flywheel, both easily obtained and not expensive.Front mains are same . RE: phoenix cranks - Ruairidh Dunford - 14-10-2018 You will require 4 x 1 5/16” rods, large rear main bearing housing and 30-32 type flywheel. The flywheels are increasingly rare as many have been snapped up by those using 1 5/16” Pheonix shafts in their pre ‘30 cars. I have successfully machined later flywheels to suit however. Many of the 1 5/16” rods available are cracked nowadays (for the same reasons as the lack of suitable good flywheels) - check carefully before fitting. The 1 1/8” cranks supplies by David do mean you can use your existing parts, which is a good thing in my book. |
